Problem: Clear Default App settings???
go to settings)apps manager)all) press left hand key of ur phone and u will get an option of reset apps prefrences click ok and ur problem will be solved INSHALLAHTALA
Fantastic.. That did it. Silly me, I was looking in 'Default Applications'... What was I thinking! <extreme sarcasm>
You got to
1 settings
2 application manager
3 left hand key, sort by size and reset app preferences should pop up
4 click on reset app preferences and it will put EVERYTHING back to defult.
Hope this helps :)
I've done this 3 times in a row, but every time I press the home button (pops up with what to use), I click the one I want and click "Always", it still keeps coming up with annoying damn popup - Any other solutions to stop it?
Edit: It's only started doing it to me in the past 2 weeks with a few things.
Everytime I try to open a video or the web.. i get the little popup box that says:
Clear default app settings by going to Settings>Applications manager>all.
I hit "ok" and I get to pick what I want to use to open it and I ALWAYS select ALWAYS...then.. next time I want to open another video or webpage.. i get the same thing. even right after I selected ALWAYS the first time.. What am I doing wrong or what can I do to make the selection I make Stick!
Doesn't work for me either. I've a different phone but this problem I've had regardless of the phone. Everything resets except the app/file association I'm trying to break.
You got to
1 settings
Hope this helps :)
I'm trying, i wish it'll work. Thanks.
Nada, doesn't work, i guess i have 2 issues now, when i'm trying to click home button it pup ups and says wich one do you wanna use, but i do not remember what it was, i guess it was home screen layot types.
HELP! Doesn't work this "perferences reseting" thing.
PmGs
