Problem enabling sync.
  • Start date Start date
A
Android Central Question
I am having some trouble getting sync to work on my device. Within Chrome settings it says "Android system sync is disabled." In another section it says "Open Android settings and re-enable Android system to start Chrome sync.
Where do I enable Android system sync? If I go to Settings/Accounts/Google it says Sync disabled, then at the very bottom is says "Sync is currently experiencing problems. It will be back shortly. I appear to be able to sync the individual Chrome items manually from within this menu.
Basically I have a whole lot of browsing data on my device that is not being synced with my PC, i.e Chrome on PC. Can anybody help me fix this? I can't figure it out! I've attached some screenshots which may help also. Thanks!
organizemeinc
