Problem Flashing Gala X Rom
We_Ready
86
I downloaded the latest Gala X Rom from rom manager and I chose to download all the extras that come with it. I successfully ran the bootstrapper and then tried to install the gala rom zip. What I get when I try to do this
ClockworkMod Recovery v2.5.0.6
Finding update package...
Opening update package...
Verifying update package...
E:failed to seek in /cache/update.zip (Invalid argument)
E:signature verification failed
Installation aborted
I'm running 2.2 OTA, could that be the problem?
I've never flashed a rom before (just installed themes), so can anyone tell me what I'm doing wrong?
are you installing it from rom manager, or are you booting into recovery and trying to install the zip yourself?
Sounds like you're not deodexed. I'm pretty sure you need to be.
Also, GalaX is a theme, not a ROM.
I am deodexed, I'm using the Droid928 Black Glass theme right now. Should I go back to original and try again.
I've tried doing it from ROM manager and tried doing it manually.
maybe try rerunning the bootstrap and flashing clockwork?
i remember running into this error before, but for the life of me can't think of the solution right now.. :(
Reactions: We_Ready
the zip would still flash over if they weren't deodexed, you just get stuck at the m logo at boot...
could you maybe walk me through exactly what I should do from start to finish? I just feel like there is something I'm missing or something I'm doing that I shouldn't be doing.
1. download and install the bootstrap application
2. open the bootstrap app and click the first icon (make sure you get a success)
3. close bootstrapp
4. download, install, and run rom manager
5. flash your recovery
6. download rom
7. click on onix concepts
8. select the gala x theme and click download
9. choose the options you want and click ok
10. when the rom finishes downloading it will ask you if you want to wipe data/cache and also backup the current rom.
DON'T wipe data and cache, but it might be a good idea to backup your rom (unless you've done this recently and don't want a backup)
11. when you click ok, the phone should reboot into recovery and flash the zip and then boot back into the OS.
that should do it. there was an update to gala x released so i typed that as i updated my theme, so i don't think anything is missing :)
Reactions: We_Ready
3. close bootstrapp
6. download rom
Thanks a bunch. It worked this time....I was skipping step 5.
Does the update make it do you don't get duplicate text meshes anymore?
Sent from my DROID X using my fingers!
Well, after getting it to work I noticed I get the same text messages twice in handcent and once in the regular message app even though I have notifications turned off.....also the GMail app doesn't work for me, every time I try to open my mail it force closes. I really like the look of the theme but it's just not gonna work out for me at this time. Thanks to anyone who helped me in this thread, I now have a better understanding on how to do this procedure.
2 text messages solution:
using root explorer (or something similar, i just find this the easiest way)
1. navigate to /system/app
2. change to R/W (button at the top corner)
3. delete "mms.apk"
4. change to R/O
done :)
as for the gmail thing, what worked for me was to update the gmail app via the market.
Reactions: rion_j and We_Ready
3. close bootstrapp
6. download rom
Adiliyo-
where can i find the bootstrap application you are referring to?
Adiliyo-
it's in the market for a dollar or two (supports the dev that is part of the few that as made the little customization we have possible for our phones)
you can also get it (for free) on his site: My Brain Hurts
i thought this was supposed to have a transparent pull down notification bar.. mine is solid grey.. anyone get the transparent pull down?
3. delete "mms.apk"
4. change to R/O
done :)
Tried this and it worked. You have yet to steer me wrong. Thanks.
Thanks Adiliyo.
Absolutely supporting the developer with paid market version.
3. delete "mms.apk"
4. change to R/O
done :)
I'm wondering if I delete this will I have to readd it to update in the future.
when i download this rom/theme from rom mgr it says 1.6.1
but when i look in the d/l dir it shows 152updated
i've deleted and re-downloaded but it d/l's the same thing.
anyone know where to get 1.6.1?
hooram95
