problem uninstalling myfiles android app - help
  • Start date Start date
A
AC Question
i rooted my s6 android 6.0.1 and uninstalled myfiles app cause it's lame, however i found out too late that there's an android features in setting->storage->explore that uses it.
i want to make it work again, by reinstalling myfiles or by any other means. can you help?
the exact error is com.sec.android.app.myfiles has stopped.
If you are using and Android version before kitkat it possible , dont install app just copy your apk using root explorer go to device> system folder > app folder and paste ur apk then reboot
But do this in your own risk ,Not dam sure that all app working again
KidColoringPage
