Problem with Guest Wifi Connection
JACKREACHER193
3
I can connect to Guest Wifi in work on my S7 not problem, but when I connect on my new Note 9 is comes up "Connection Not Private" - I've googled and done all the fixes they suggest (clearing cache, checking date/time) but still won't work.
Wierdly when I look at the wifi settings on both devices they have different router addresses which I think may be the issue (security certificate hasn't been updated with new router address)?
Any ideas?
Any ideas?
With mine, I pick no security certificate, and it works.
thanks for reply! - how?
It was just an option (on mine anyway), when attempting to connect to the work's wifi. They have a Guest and a regular Work wifi. Come to think of it, I think I was connecting to the Work / employees wifi. But I would think the Guest wifi doesn't require the security cert either, but I'm not sure. I think it depends on how your work sets them up.
mostafamu
