problem with phone.apk
ohfivepro
Active member
Feb 13, 2011
44
3
Im using Xionia cm7 build and works fine other than when dialing a number using a wait (;) or pause (,) command only the first command is used then when you hang up the rest of the commands flash on the screen.
i tried using different phone.apks from different roms and all have the same issue.
is anybody else having this problem, if so is there a fix?
so am i the only one with this problem, can somebody confirm this? 18005551212;1;8902340 this will only prompt the "1" but not the 8902340
