Problem with samsung galaxy s 3 starting
matt_perrin97
I was using my phone, listening to music, then it suddenly turned off and it wouldn't start. This has happened a number of times but the first few times i just took the battery out and used the power button then put the battery back in and it turned on. But this time i tried that and it didn't work so it tried putting it into recovery mode (power button, volume up button and home button) but that hasn't worked. Is there anything else that I can do?
hmm... that seems to be somewhat weird !! Well if you can't get yourself over the bootloader then I think you may need to go to the support for fixing it !!
crayzeefoo
