Problems after doing GB...
justguff
23
So i'm incredibly new at this. I rooted a few months back, stayed with the sprint lovers rom and just dug on that...i thought about flashing but wasn't confident to sit down and do it (and, simply, i was too busy) well after numerous attempts from my phone to get me to do the GB update, and my gps signal failing miserably, i figured it was time to do something.
So last night i went with gb (not ota, from [ROM][STOCK] --- Version 4.22.651.2 --- Odexed & De-Odexed --- - xda-developers) since then...my space has been low. Aside from that my gps seems to be working, i had to redo some settings and reinstall some apps to get them to work properly, aside from that, though, it's just the memory issue.
For now i uninstalled some apps, many i'd like back, but if i'm not going to have room..what's the point?
here's the kicker, and flame away, but i flahed a rom? yes? or...no? that's the bad part...i don't even know.
If i did, and it's JUST that simple...i may have to go to something else, but what??
ok.. If you Flashed a zip from that [ROM] thread.. then I will assume YES you did. You just flashed a ROM. If you are on a diff "OS" than you were running previously on your EVO then your "flashed" a "ROM".
Now time for your next feat... Flash another ROM and get comfortable with working in Recovery etc...
