Problems flashing the radio
donavan
582
162
So I tryed flashing my Radio to the version called for by the cyanogen wiki and it seems to update with no errors but once its done and I reboot using the camera and power button I don't see the change. Anyone know what the deal is I noticed one place that there are update-able and non-update-able radios is this true? Has anyone had this problem and figured it out?
Ok problem solved. Apparently what you had to do was actually reboot from Amor RA 1.7.0 rather than just shutting the phone down. Apparently when the radio update runs it doesn't actually do the install until after the phone begins the restart. So long story short make sure you reboot rather then just shutting down.
BNIDirect terkunci
