Problems rooting my phone
Not knowing anything about your phone but knowing enough about ADB/fastboot, make sure that you have the LG driver installed(so that your phone is a recognized device on your PC). Don't forget that a reboot may be needed post install. And if that doesn't help try unplugging/plugging the USB cable. Usually the problem is the former but the latter doesn't hurt either. Alternatively make sure that USB debugging is turned on. Although if it wasn't I think you'd get a hard failure.
If all else fails. Post this in your respective device forum. I'm sure someone there can zero in on the issue.
I unroot my phone so that I could try to upgrade it but now I can't upgrade or even root it I have a incerdible 2 NEED HELP
This isn't the right forum to ask this question. Go to the rooting forum for your phone and you should be able to get some good help.
We love Android,Don't root your phone just for the sake of rooting your phone,Rooting your Android phone enables you to use the superuser.
FelipShar
