Problems running Launcher Pro
ob1droid
Just got an ATT Captivate. LP does not show in the Applications. I can find it on the Setup/Applications menu but, of course, can't run it. Is there something I'm missing? I'm not running any new "home" apps.
Thanks
When installed the phone should bring up a menu when you click on the home button and ask for twlauncher or launcher pro! Just click on launcher pro on your phone to run it! The last version I had problems running it on my captivate because it would lock up!
HTH,
Charlie
Sent from my SAMSUNG-SGH-I897 using Tapatalk
If you having issues getting LP to activate grap the app Home Switcher. I will allow you to change the default launcher that is being used. I think some vendors are intentionally disabling the flag that allows users to change launchers.
heritagevine06
