I was running Thundershed 1.6 and was having alot freezes. I went into recovery to flash my GB .9 nandroid and when i got to the 4EXT menu a message appeared at the bottom of the screen saying "Unconfigured. Use 4EXT app to set me up" which i've never seen before. I contiued on because there was no sense in going back and putting up with constant freezes. I wiped cache/dalvik, formatted all partitions except SD card, and formatted system/data/cache. I selected the nandroid and the message "Considering your selection and files contained in this backup, i'm about to restore: boot system data cache" appeared (which is normal, right?). Everything was fine until "Error while restoring /data!" appeared. I tried to flash nandroid again and this time "Error while formatting /system" appeared. I then tried to restore my nandroid of Thundershed but got a "status 1" (?) error while trying to do that. I powered down and rebooted in recovery. I started to poke around in 4EXT a little and noticed that data was mounted and i couldn't unmount it. I wiped/formatted again and tried to reflash both nandroids which still didn't work. Rebooted into recovery and was able to unmount data but cache and system had mounted by themselves which i haven't seen before. At this point i figured i just try to turn the phone on and see what would happen and i got the htc white screen, thunderbolt boot animation, and then eventually the home menu with this message in a dialogue box: "System UIDs on the system are inconsistent, you need to wipe your data partition or your device will be unstable. I'm Feeling Lucky (button)." The only way i could proceed was to tap the button. The default wallpaper was back but the layouts on the homescreens were the way i had set them up except instead of icons for the apps, there were squares which said "problem loading" or something like that. I rebooted into recovery wiped/formatted and then restarted phone but this time i couldn't get past the boot animation. I could type a few paragraphs about what i've tried but nothing has worked. Desperately looking for help.
