problems with android market
palanilopez12
155
I am not rooted...i was able to download and update apps last night just fine...there are still a bunch of apps that need to be updated and they will not install...even when I try to download apps from the market it just won't work...is anyone else having this problem?
I don't know what time you guys read about the market being down, but it's STILL down here in CA.
wow ok I don't know what is wrong with my phone then...restarted it...pulled the battery...pulled the sd card...and i still can't download anything or update any of my current apps...this is really frustrating...any other ideas?
I'm in Hawaii as well and can't get it to work
This happens to me sometimes. I usually uninstall the app and then reinstall it. You will lose any settings but it's the only way for me to get the update.
I don't think it's your phone. The market started working again late last night for me. But before then, I had checked it on my sisters Shift, one co-worker with an Epic and another with a Droid X were all having the same issue. But it seems to be back to normal now.
Yesterday I had trouble with purchases. Seems they for it together later in the evening. Probably had something to do with google io.
Sent from my MB860 using Tapatalk
I'm having problems with this now too! Im in Ca on Evo.
I dont know if this is the same issues... I tried to "update all" last night ( 1 by 1 worked fine) and this morning it is stuck updating my apps even though I canceled the updates... My phone now keeps rebooting and is stuck in this loop! This happened to me last month too? I cant download any new apps or even uninstall any apps... I powered down, pulled the battery unmounted the SD card.. nothing is working! Is this a different issue!?!? Please help this is very frustrating!
I don't use "update all" anymore. I update each app one at a time. Always one or two apps that never appear to finish loading. Also, if you do use Update All, it may show "loading" but it may have been already installed. Check the market page and see if it was installed.
Another thing I do is I uinstall the original app and just reinstall it. That way the new update is included. You may lose settings that you may want to keep, so be careful if you do this.
almeshkatrt
