Problems with Crackle
No not at all. I guess we have to wait for an update
I'm having the same issue. I thought my work wifi was blocking the streaming for some reason
Don't have a SGS3 but have you tried watching Crackle through the browser? You may need to set it to desktop mode.
Reactions: rgh718
I am having the same problem, I just read the notes from the developer of this app and it states this app is not yet supported on the galaxy S3.:thumbdown::confused:
at least we now know that they know hat it doesnt work, and is hopefully working on it
Thanks for the idea. I was able to watch movies.
Crackle works perfectly one my one x. I hope it is fi,ed soon.
Sent from my HTC One X using Android Central Forums
I found how to use the old version. Goto developers section and select force apps to use 2d acceleration. Crackle will work. Now the update works as well. But every now and again after a reboot I get a pop up saying Crackle stopped. But it works if click on the app. Anyways just my 2.5 cents. Happy SGS3'n:cool:
Play store now says my phone SPH-D710 not compatible with Crackle app, also heard it's no longer compatible with certain Kernel versions ie. ff18. Used to work before update.
