PSA: For anyone on TMobile prepaid - you need data roaming on!
Wow. I'm sitting in the ride-share parking lot in town where I usually get 2-3 Mbps, and now I'm getting almost 16mbps! I also noticed my data bar stays on "H" instead of alternating between 3g and "H".
So far in Connecticut there's only a nominal increase in speed, but my pings went from 400-500 to ~50ms.
Thanks for this info. I was wondering why I was not getting HSPA+ speeds when I turned wifi off at home. I was only getting about 750kbps download with data roaming off. Went up to 3mbps as soon as I turned data roaming on. I am hoping it improves.
Did you also reset the APN? That made it go up even more for me.
I am not on prepaid but am on T- mobile and this fixed latency for me. 15x improvement. Thanks.
I guess it's TMobile's network in general that needs this. Why don't they put this in their instructions? Clearly their customer service rep knew about it.
Does anyone know why you are supposed to reset your APN? What's the purpose and what happens if you don't do it? The reason I'm asking is that after doing this, I got my first ever Tmo web site pushing me to sign up for HotSpot service and only displaying this page (I was tethering, using my pc) whenever I clicked on any links or bookmarks. I don't tether much, but I've never been redirected to this site before tonight (after resetting my APN).
Resetting the APN causes the phone to renegotiate with the network so everything's "fresh".
Well, without data roaming turned on for me, I'm getting the speeds the OP talked about needing roaming on for, so... maybe it depends on the market?
Someone should sticky this post. HOLY SMOKES! Worked for me out here is metro Detroit!
Big thanks to the OP!
Did you reset your APN?
- - - Updated - - -
Yup. Also rebooted and still have horrible pings. Holding onto 3G better though, don't see the dreaded E as much.
Just tried some more. The best was 73ms ping, but .43 mbps dl, and 1.25 up. Worst was 630ms, 1.74 dl, and 1.23 up, this was when I changed the server to one that T-Mobile hosts.
Any other Nexus 4 forums that this info can be spread to?
It's not just the Nexus 4. A friend with an HTC One S saw the same improvement (from about 3mbps down, .5mbps up to 12mbps down, 1.2mbps up). Are there general Android forums where this is a relevant post?
Didn't help for me. My speeds actually went down. Maybe I'll try again later...
I am getting a worse connection this way :/
Does anyone think this might be applicable to the galaxy nexus on T-mobile too?
I used to get great speeds in Boston but I've had pretty crappy speeds (and awful pings) for a while now and I realize I turned off data roaming a while ago when I was traveling (and wanted to make sure I didn't roam on data).
Also what does resetting APN settings do?
Does anyone ever get a message about signing up for hotspot when tethered to the Nexus 7? That is the only kind of tethering I use on a regular basis. (So if it was messed up by this process I would be very sad).
Update: Ok just gave this a try. Hopefully this also helps the galaxy nexus. Also I have grandfathered even more plus plan so I'm not sure if that makes a difference.
affansahab2021
