Qi Chargers
This has reflected my own experience.
Purchased the LG charging pad at Verizon (had to go there to tranfer my daughter's phone number over to my now retired Razr!) and so far, it's working great!
I've only heard it beep when I put the DNA down on it, I don't have to worry about making sure the DNA is positioned properly, it seems to charge the device anywhere it's placed on the pad, and it charges quickly!
For me, I discontinued our home phone a couple of years ago. Having my previous Razr plugged in to charge, with the short cable provided by Moto, every time the phone would ring, I'd have to unplug it, take the call, then plug it back in when I was done with the call! Total hassle!
Now... I simply pick up my DNA... answer my call... then place it back on the pad when the call is completed!
Easy peasy!
The LG is working well for me although my DNA does get warm -- 96 degrees on the front and 99 on the rear after charging awhile. (Measured with infrared temp gun)
I've called 7 Verizon stores in my area yesterday searching for the LG charger and none of them have any. So I went online and they seem to have removed it? Can't locate it anywhere other then Amazon.
Sent from my HTC6435LVW using Tapatalk 2
That's where I ordered it from because it wasn't on Verizon's website.
Sent from my Verizon Note 2, finally!
Why would they remove it?
Maybe because they are out of stock... The LG seems to be out of stock in all the usual places to buy.
If you don't want to wait for it to get back in stock, see if you can find an Energizer. I have one of those (as well), and it works great.
I went to a tmobile, att, nothing. Oh well just gonna rip the cover off.
Yes I am using a Defender with the LG QI charger, took about 6 Hrs. from 3% to 100%
Shows the charge cycle.
I picked up a couple of DT-900s and they work great with my DNA. Kind of $$$, but really convenient. Next thing to get one rigged up for car use when I have NAV running!
i wish someone made one that's horizontal upload right.
and the phone switch to night clock automatically.
There's an app called better desk clock that has a setting to automatically go to desk clock when plugged into usb. It also works when phone goes into wireless charging mode. App cost $1.99, but works great and nice developer.
My LG Qi charger works perfect. I did notice that if you put your phone upside down on the pad (pad charger power port at bottom of phone) it will not charge and just constantly beeps, so it is possible to place it wrong.
I just the Verizon universal charge pad (it's the LG Qi charger) and it's so nice to not have to plug the USB in.
It only beeped once when setting the phone on it then the green light starts flashing.
BUT it never stopped flashing, I thought it would go steady when charged but it didn't. it just kept flashing but it charged to 100%
Just bought the Nokia DT910 upright charger from a local ATT store. Working great!
Same here.. I got the DT900 when I ordered the phone and it's okay but, really small.. I'm using it for my bedroom charger and using the DT910 for the living room. It's perfect.. I'm thinking about getting a fatboy pillow and then I'll be done :-\
They needa design a solar powered qi car dock, no wires at all...wonder if that exists anywhere, any word on any offciall HTC car dock for the the DNA exclusively for the DNA??
Sent from my DROID DNA using Android Central Forums
Ashok Dharshan
