Qi Chargers
The Body Glove DropSuit can stay on the DNA when on my Verizon-branded LG WCP-700 Qi charger. Also, placing the DNA sideways on the LG charger allows the phone to "breathe" a little while charging and lowers the maximum charging temperature to the mid 90's from the high 90's.
Do I need a special cover or sleeve to charge on the Nokia dt-900? Also will the phone receive text messages and phone calls when on the charger?
I just got the Nokia DT910 and found it works fine with the both the Verizon silicon and Diztronic cases.
I bought a DT-900 yesterday, got it home and it didn't work. Went back to Verizon and they tested with a htc windows phone as well as a new DNA, they both worked so I'm getting a replacement phone today.
I can say that with my DT910 that i can send\receive text messages and take\make phone calls while charging. I would presume the same with the DT900 but I make no promises :p
FYI new phone works perfectly with charger.
Is anyone worried about wearing out the battery when using these? I think if I bought one I'd be tempted to just set the phone down on it every time I wasn't using it. Since it doesn't have a replacement battery, aren't we working on a limited number of charge cycles here?
No, you don't need any special sleeves or anything. Just place the phone on it. Yes you'll receive calls, texts.. etc
Maybe because they are out of stock... The LG seems to be out of stock in all the usual places to buy.
If you don't want to wait for it to get back in stock, see if you can find an Energizer. I have one of those (as well), and it works great.
I found one on Amazon yesterday
Sent from my HTC6435LVW using Android Central Forums
My understanding is that there are a limited number of charge cycles, but it is related how much the battery recharges. I think that for most LiOn batteries, there are about 500-700 full charge cycles (before the battery starts to lessen in its capacity), but that is based on a full charge. However, if that battery is recharged from 50% to 100%, that is only 1/2 a charge cycle, so if you recharge at 50% each time, you basically get 1000-1400 charge cycles. Waiting to recharge the phone until it is 90% dead (100% discharge isn't good for LiOn batteries), will use up almost a full charge cycle, while recharging the phone 2x from 50% to 100% will use up 1 full charge cycle.
So I don't think there is much benefit to trying to run the battery longer. I guess the only way to really extend the life of the battery is to minimize the actual use of the battery, which kind of defeats the purpose of having the device.
There is new technology that looks to extend the numbers of charging cycles, and reduce the time to re-charge, hopefully by the time this battery wears out, and the phone is replaced, some of that new technology will be in the new phones 2 years from now!
I'm planning on keeping this phone for at least 2 years. I'm sure by then there will replacement batteries on ebay. It wont be easy to swap out but should be possible.
Lithium Ion batteries have low voltage cut-offs built in to them. You can not over discharge them. They will shut off before you can damage them.
Sent from my SCH-I605 using Tapatalk 2
Anybody run into the issue like this?.... I just bought the Nokia 900 from Verizon and it worked right off the bat with my DNA and Diztronic case and started charging it on my nightstand before bed. About 2am my room lights up as the screen of my DNA came on stating that it was no longer wirelessly charging and then switch back and forth between connected and not connected. After switching a couple times between not connected and wireless charging it started charging again and the phone went back to sleep. It only happened the one time during the night that I am aware of, but I'm wondering if other people have this happen periodically? Hopefully it's just a fluke
That sounds normal to me. It sounds like your phone charged up to 100%. Then, after hitting 100%, your phone stopped charging like it is suppose to. After it ran down a bit, it started charging again.
Do any of these chargers have an on/off switch?
I know they don't draw a lot of power, but I see no reason to leave it on all the time.
Ed
BTW - this is my first post! I love the DNA, it's my first smartphone.
I thought that might have been the case when it came on so I looked at the battery % and it hadn't hit 100%...it was closer to 85%. It hasn't happened since...so I'm hoping it was just a fluke.
Ed
If you turn the charger the phone will continue to drain battery on standby just as it does during the day once charged so I would not expect them to have one any more than any of the charging docks do.
Just picked up two of the LG WCP-700 Charging Mats from local Verizon store. I decided to take them apart and remove the speaker. Worked fine when I put it back together. The charging pad is just the right size for the DNA.
So far so good, I came from a Palm Pre and I liked the touchstone. So much easier not having to mess around with a microUSB.
Ashok Dharshan
