Question about 5000 mAh USB external battery pack
Hydraulic Jack
189
I was wondering....If your phone's battery gets to say 15% and you plug this in and then use the phone as normal (on with minimal use) will it still charge or at least maintain the 15%? HJ
It depends on what you are doing with it. Making calls,playing music, browsing, playing Temple run 2 it has charged but playing Slender man it slowly drains. Also using navigation it charges if screen dims but if screen stays bright it slowly drains.
Osakiihsja
