quick way to turn on flash light
Scumperjumper
159
Hey guys I need a quick way to turn the flash light on. I have the lg h815. I tried click light but it didn't work at all. And I cannot find the assistive light widget or light widget that was there on my galaxy. Help.
Does the app Key Plus not work on your h815? This app allows you to turn on the flashlight by double pressing your volume up button.
Swipe down from top and use the quick flashlight setting 8n the top row. You can move all of those setting around to fit your personal needs.
I have the flashlight set to the far right on my phone.
Tried to add a screen shot but it doesn't recognize the file format for whatever reason.
Download Power Toggles from the Play Store. That has what you need.
I does but I use the volume functions like camera and memo
Thanks for the Key Plus tip. I thought it didn't work at first, but I had to turn short cut functionality back on in settings. Perfect now!
kctraci1
