- Aug 30, 2012
- 598
- 0
- 0
You know how if you go into "battery", you see a percentage next to apps? Is that the percent of battery CURRENTLY being used by the app, or the battery consumption since your last charge? Because I have two battery-eating apps (GPS navigation) which are at 15% and 8%. I can't tell if that's the amount of battery they're eating at this moment, or if that's how much I just consumed using them.
I can't "force stop", because I already turned the apps off (there was an in-app button). So I hope they're not currently eating up a ton of my battery lol. If it is the latter, how do I check current processes eating battery? Thanks!
