Random long vibrations.
Sent from my HTC One X
It just makes a bugreport. It hasn't had a negative effect on my phone, and it's been sitting there for a month. I did delete it for fun, though :p
Hmm...my phone just did it as I was reading this post but when I went to look for the folder it wasn't there. Oh well, it doesn't really bother me all that much.
Sent from my HTC One X using Android Central Forums
Sounds interesting but volume up and down can't be pressed at the same time because it's a rocker switch.
Sent from my A700 using Tapatalk 2
I managed to pull it off, since my rocker is a bit loose. If it doesn't work, try pressing up and down in rapid succession for a few times and a vibration should occur.
Well,just had another one. Was usuing the Ac app,then it vibrated. It doesn't stop vibrating unless you press a soft key,but so nobody knows of any reason why it does it.?
Sent from my awesome HTC one x(:
Well,does anyone with a tegra 3 one x experience and random sporadic vibrations anymore.?
My one x is better then your one x!!
D:
Never have experienced such a thing.
Sent from my HTC One X using Tapatalk 2
I've had the AT&T version of the One X since April and haven't experienced this problem...the phone has pretty much been flawless.
1am, huh? Ugh, fun times indeed! Glad you got them though!
Your G-1 first look video today was great! I love that you can add Folders to the Home screen and put stuff in it like your games. Sweet!
I have the same one but dunno what the problem is,seems to be tied down to the s4 AT&T model cause no tegra 3 owners have said anything if theyve experienced it or not. Well,I told HTC and they said to do a soft reset meaning just reset the phone which I have done but problem still persists. These vibrations happen outta the blue. :confused:
D:
toolman61
