Really Need Help
Its about half way flashed with odin on my end so Im not sure if i should have went ahead and flashed the zip file or not but... its in the process?
The second file you flash as is, do not extract any of the files in there. anything you flash in ODIN should end with .tar or .tar.md5
I extracted and got
- - - Updated - - -
I flashed the whole zip and it did nothing so i guess i flash the md5 file in there?
That was the 30 minute download you gave me, i flashed the entire zip file as one and it did the normal thing, passed, rebooted, and got stuck
yes. that file.
it ends in .7zip....you need to extract the .tar file from there, but do not try to extract the .tar file itself. that is the file you are going to put in odin
it should be named: root69_ATT_I747UCALG1.tar
Im starting to think the phones shot.. Haha, is there any way i can at least get it back to what i had before all of this?
Unless of course you have another idea as to fix the current issue.
texmaster
