Reboot when pressing power button on Lollipop
tongrhj
16
Nexus 4 on Lollipop Android 5.0
Rooted
How do I get the option to reboot from the power menu (the one you get when you long-press the power button)? Thanks!
How can I power off? Now when I hold down the power button, nothing happens. No more option of choosing between powering off and collecting a bug report. Instead, the screen stays lit and then goes dark after I let go of the button. But if I hit the button again, the screen turns back on.
Odd... This is what you should get...
Yup. And I did for the first few days after upgrading to 5.0. Then it just disappeared. Strange.
I wonder if it's related to another phenomenon I recently noticed: The phone occasionally takes itself out of Battery Saver mode.
Sounds like a factory image flash is in order.
You mean via a hard reset? I did back-to-back hard resets with 4.4.4. I got the 5.0 OTA a couple of days after that, and nearly everything was fine -- certificates were the exception -- until a few days ago, when this power button issue popped up.
I know it doesn't come baked in. I used to enable it with Xposed Gravitybox (I think).
Now that Xposed isn't compatible with Lollipop, I have so many missing features I need back in my life. Reboot from the power menu is one of them. Having a dedicated app is a terrible solution because it's so unintuitive.
The author if Xposed has stated he isn't going to support Lollipop... So best to find another solution. Many custom ROMs have a lot of the same features.
my nexus5 after updating to lollipop starts rebooting whenever i press the power button for about 2 seconds and at times the screen blinks and starts to reboot but doesn't start.Any solutions?
liquidsnake757
