Recommended setting for battery ?
gill.batez
23
Hi All,
I am using Atrix 2 for 2 week now and I am not satisfied with the battery performance on my phone. My battery lasts only 10-12 hours. Can you guys please suggest your settings and battery performance so that i can also apply those settings and check/compare the battery performance on my device. I just want to make sure if my battery is faulty or my settings are causing more battery drain.
My settings:
I have Data and background data enabled.
No vibration on screen or key touch,
social sites sync is after every 30 minutes.
Wifi is on most of the times,
Lowest possible brightness setting,
No pocket detection,
Data Saver disables,
Battery mode : night time saver,
No GPS,
Please help.
Thanks.
We pretty much have the same set up & I get the same average battery life. Coming from an iPhone maybe I'm ignorant to this battery life issue you have cause I would've had 6 hours at best, lol.
I would recommend turning off the syncing of the social sites. If you do not want to turn it off, then you should increase the time period to atleast more than 2 hours.
Nehasingh12
