[Recovery] CWM-Green w/BacksideUpdater Auto-Install
I have a similar question to the above poster, that I could use help clarifying before I install. I also have clockwork installed. Will having clockwork installed interfere with installing backside? Do I need to remove clockwork? Will the img just be a complete wipe? I would prefer a complete wipe. If I just need to run flash_image recovery /path-to-recovery-image/name-of-recovery.img how do i get the the terminal or do i use the terminal in clockwork? Thanks.
Edit: I successfully did the term command in term emulator however there was no changes in the behavior of my set.. It still just booted into cyanogen like it normally does.
Google Flash Image GUI and rename the recovery.img to recovery.img, it is an apk's file that has its own flash_image binary.
I am running an LG vm670 stock 2.2.1 with the zv4 baseband. Have gingerbreak installed and su access for all Apps. I have no PC access and am trying to install cm9 bobzhome android ics to my handset. Got cwmgreen above but in android terminal emulater it says " flash_image " not found when I type in the command to flash the recovery. What gives? Any help would be greatly appreciated on the best way to root this baby to ics bobzhome withOUT a PC.
Do exactly what the post above you says.
Sent from my LG-VM670 using AC Forums mobile app
sellhousefastmke
