Recovery Mode Help
Encerspay45
619
32
Hello, I'm currently in Recovery Mode on my Optimus V, trying to flash a custom kernel.
I'm a total noob, anyone want to help me out on what I should do to flash it?
I tried clicking "install zip from SD card" but it didn't do anything but show the ClockWorkMod logo, then I had to go back to the original menu. Help???
Thanks in advance.
Thanks in advance.
If it shows the CWM logo alone with no menu, most likely you have the Bobzhome recovery and simply pressed the Home button. In this recovery you must use the Camera button to select, which will bring up the correct menu.
As an alternative, if u find the camera button a little vexing (as I personally do), you can flash JerryScripts CWM Green recovery which uses the Home key as select.
Hope this helps you
Flash image GUI from the play store will work as well...be sure to clear both caches though and backup before trying a new ROM ;)
FahadsTech
