[Recovery] ZenGarden 2.0.3.3-T ............. 01-30-2013
Re: [Recovery] CWM-Blue-Recovery V5.1.4.1 w/IHO Updater 12-03-2012
What's new ?
Sent from my VM670 using Android Central Forums
Fixed an error that caused the Auto-Install to continue even if Auto-Backup failed. Sometimes the sd-ext partition may get corrupted which will create problems when preforming a backup, because of this if the ROM was Updated it would cause System Inconstancy Errors.
Clicking vm link and keep getting ls download :(
Are you using the Android Central app, and do you have any Social Networking apps installed?
Yes and yes. The download say's ls670.
I did get the ext errors above. When I rebooted process acore had stopped :(
Hopefully I'll be able to download the update.
Edit: O got it from rom thread :D
X2 on the ls670 on both links...
I opened in a new window&all that ..
Update:
CWM-Blue is now ZenGarden Recovery in both touch and none touch version.
Edit: Uploaded the LS 670 version of the touch recovery.
Re: [Recovery] ZenGarden Recoveries for 12-05-2012
Update:
CWM-Blue is not ZenGarden Recovery in both touch and none touch version.
Confused
Sent from my VM670 using Xparent Pink Tapatalk 2
You make some badass recovery :D
I went back to original because when I choose wipe option it wipes,but then hangs on loading screen on the touch recovery :what:
Re: [Recovery] ZenGarden Recoveries 12-05-2012
:) Most of the hard work really goes to the dev's before me.
Just noticed the problem with the Wipe Data Menu, well have a fix for the problem in a couple of days.
Issue with options in the Wipe Data Menu causing the recoveries to freeze up if ran has been fixed, to those that downloaded and installed within the last couple of days and had problems sorry, and thank you for your support. Please be sure and leave feed back. :)
Re: [Recovery] ZenGarden Recoveries 12-08-2012
What a beautiful recovery. Full wipe worked perfect :D
Thanks again
I have a wildfire s cdma. Is it possible to flash this recovery on it ?
Thanks again
You can try, but the recovery image would have to be unpackage replace the kernel with one for the Wildfire S. I would as a development for the Wildfire to look into building one for the phone, the can pull the source from my github repo.
So far so good. People might want to stick with the adb method. I had a bad flash the first time I tried to use flash image gui (the second time worked fine). I love the look. Touch controls are very nice. I'm making my first backup now. Thanks EarthnFire78!
ZenGarden had been updated, please check it out.
I went to Key Test in the recovery and I cannot exit the menu. It shows "Key: 855204" for every button I press. Looks like I may have to pull the battery. This is not a big issue, just a little bug. Also, the main menu shows "Wipe Date" instead of Wipe Data. Very nice recovery!!!
Not really a bug, just forget to take into account of the touch control in the source. Well have this fixed and some grammar typos as well.
Re: [Recovery] ZenGarden 1.6.7.3-T ........... 12-21-2012
Great work but I have a question...if I install and use this recovery will it flash jellybean. I have the green recovery by jerry script installed which has given me not 1 problem on any rom so far jellybean ics ihookup etc. Will this recovery give me problems or is a keeper for all roms? Also does it contain a SD ext partitioned? Thanks G
Tested well with flashing ICS ROMS, so JellyBean should flash fine. Look under Utilities Option and you'll find what you looking for.
pramanj96
