Recurring problem with proximity and light sensors after the latest OTA security patch
kanj_mobile
Hi
I have a 16 GB nexus 5 purchased in December 2013. In the original KK OS proximity & light sensors worked fine.
But ever since I upgraded to lollipop, I have observed that these sensors aren't working most of the time. (Screen won't turn off when I bring my phone to my ears, screen brightness won't adjust to ambient light, etc.) I download an app from play store which displays sensor data but it was also unable to show any data from proximity & light sensor. Both these sensors are from a vendor- Avago and HW version is 2.
This problem was pretty severe immediately after 5.0 upgrade. After 5.1 upgrade it became less frequent. But after the last security patch from google, these sensors stop working 2-3 minutes after the device boots.
My friend has a 32 GB Nexus purchased in 2014 with the same sensor HW. But he doesn't face this problem. (He has some other issues in his phone.)
This is definitely not a HW issue because as soon as I flash KK image, everything starts working fine.
Is anyone else facing this problem? Is there any way to fix this? (I suspect the fix would involve clearing data of an app,)
Thanks
Kanj
Welcome to the Nexus 5 forum. :)
First, try a Cache Partition wipe.
Tell us what that does.
Hi
Thanks for your response.
I factory reset the phone and wiped the cache partition too using the bootloader menu.
But it did not solve the problem.
