Red charging light
Ron Copsetta
206
Just wondering why my red charging light isn't always on while the lg g4 is charging, sometimes it's on and sometimes it isn't. Anybody have same issue.
It does slowly cycle the brightness, but that's normal. Are you saying sometimes you plug it in and the light doesn't come on at all? If so, what about the on screen indicator? And does the screen itself even turn on automatically when plugged in?
If none of that is happening, then it's not charging. The usual culprit is the USB cable going bad. It's also possibly a bad USB port or charger, but those are much more rare.
Should all ways be green or red when plugged in. If it is not there is a connection issue or not enough power is coming from the charger.
Deinenxo
