Redmi note 5 stuck in fastboot(even after hard reset)
  • Start date Start date
A
Android Central Question
I recently tried to root my phone by flashing TWRP recovery and then installing Magisk, I successfully unlocked the bootloader and got TWRP recovery on my phone. I did not find the Magisk zip file in the install menu of the TWRP, so I decided to use the Magisk manager on the normal system to root my phone. However, when I tried to go back to System by selecting Reboot -> System, it goes into fastboot mode, after that, I cannot get into normal android. I very recently bakced up my phone for unlocking bootloader so I am totally fine with losing data. I am still able to access the TWRP recovery. Also, when in TWRP recovery mode, I wiped data using the Wipe in TWRP, I also ran these lines in minimal ADB and fastboot to my phone before I got stuck in fastboot:
>> fastboot erase boot
>> fastboot erase cache
>> fastboot erase recovery
>> fastboot erase system
>> fastboot erase userdata
>> fastboot flash recovery TWRP.img
>> fastboot boot TWRP.img
Maybe these liens are what caused the problem.
Here are things I tried but didn't work:
1. Android multi-tool, I used it and chose 7(exit out of fastboot), didn't work, phone just goes black then goes back into fastboot.
2. TWRP recovery -> Reboot -> (All of the options, I tried all four, just boots into fastboot)
3. Android multi-tool wipe data, I'm not sure if it actually wiped data since I can't check.
4. TWRP recovery -> Wipe -> Format data, same here I don't know if the data is wiped.
5. Pressing the power button for 15 seconds, screen goes black, then back in fastboot.
6. Minimal ADB and fastboot -> fastboot reboot, same thing, screen goes black, then back into fastboot.
7. Depleting the battery then charge and power up, still goes to fastboot.
Please help me solve this problem, I tried everything I know of, and now I have no idea what to do, I really need my phone, please help.
Darek
