Removed task killer, now phone is a bit sluggish
Imho from using this device, a seperate app shouldn't be necessary to keep your memory at a good level. For me, all it takes is opening Settings -> Applications -> Manage applications -> and from here I click the menu button and press Filter. Then select Running and now you see all running apps. From there I just close off any app I know I don't need running (emulators, browser, Pandora, etc.)
way too much work, there should be a simple one click close, not with the froyo not allowing this it sucks.
Really, in Froyo you should just get over the previous-gen idea of managing the memory yourself and just let the OS do it. Especially with how often threads are shared between programs, it's just not worth worrying yourself over it.
slackingfred
