replacement charger.
bigmick777
218
My g3 (d855) Came with a uk plug 1.2 mah charger and usb cable.
Out of all my chargers it has been by far the best. Suspect the lg cable which was labelled as 20awg helps.
Anyway, I have lost this faithful charger and want a genuine or solid performing replacement. EBay genuine items worry me and a lot of the "genuine" chargers listed are 1.8mah. So thought I would get any feedback you guys may have....
Mine is D855 and came with 1.8 Amp charger ... And you may also get one of the smart chargers that adjust the amperage as your phone needs ... I use one called Anker 5 port 48 wt charger with power IQ technology and it is good so far ... Hope this helps ...
Sent from my LG-D855 using Tapatalk
daanko
