reset droid, stuck half way to stock
agentkorey
3
I rooted and did the voodoo lag fix on my fascinate. When I started to look through roms I realized i was on DH12 instead of D101. I decided to restore to the original back up I created right after root so I could try to do the OTA update to D101. Long story short everything is gone off my phone including the CWM and when I try to go into the market place it will not allow me to download anything. I get the error saying memory is full.
I tried to flash the stock fascinate rom with Odin and it still has the same error. I found some people that said to remove voodoo but I cannot get the unlagfix to run because i lost root superuser permissions. Ive been searching for over an hour and cant seem to figure out how to just reset everything to bone stock. Thanks for any help!
The adb is pretty intense, it doesnt like the java I downloaded and wont load up. Is that the only way to do it? If it is ill try to figure it out, that just may be above my head if there is another method. Thank you for the quick response!
If you can get into clockwork recovery, you can try flashing the uninstaller attached in that thread above. But it doesn't always work like adb
No nandroid restores, no rom flashing in Voodoo di01
ADB needs Java SE. Get it here. You can try the uninstaller zip from the xda thread if you don't want to get into shell commands.
dewiit
