Restore fonts
lancer1991#AC
46
3
Anyone know how to restore the default I'Ve fonts? Used this Font Installer Root app and didn't realize to create a backup within the program and now if I change the font in settings it doesn't change all as the app permanently overwritten clockopia.ttf and roboto-regular.ttf.
lancer1991#AC
46
3
Thanks, but guess I should have said I also spent 2 hours trying to push files before and couldn't do it. I would either get device unavailable, permission denied, or any other version of "no" a computer can tell you.
I'm no pro at this, so sure I was doing something wrong, but kept searching my errors and no resolve.
EDIT: I may have gotten it to work. I used the "cat" command and a different "mount" command and noticed the change in file sizes after the process. Only problem is, and maybe this is how it normally is, but in the Gmail App the subject will have the font that is setup in the Settings>Display>Fonts, but the message text is different.
JayWill
2,631
571
Yeah use ES and make sure to enable root access and mounting in the settings.
Sent from my SPH-D710 using Tapatalk 2
hellofello
