[Retired ROM] Aphrodite 2.0.1 w/Xionia 010 (13apr11)
my phone was doing the same thing and so i installed the xionia thing to my sdcard and followed all instructions on that identically. now its stuck on a blue screen that says:
fastboot mode startred
gpio_i2c: invalid khz: 0
bl: i2c write error
udc_start( )
-- suspend --
-- reset --
-- portchange --
-- reset --
-- portchange --
im confused and i don't know what what a adb is to even try and "flash" that or whatever all i know is i used superoneclick to root it and i tried uninstalling everything cuz i figured it didnt need to be like that since i didn't know what i was doing. figured i would factory restore my phone just to be sure it was gone and it rebooted into clockworkmod recovery. i downloaded xionia since everything i looked up about it said to do that just lead to a blue fastboot screen. im lost i just want my phone back smh
Did you make a nandroid backup?
Use that to restore everything, then flash a more modern rom. This has not been worked on in months.
Also, this a recovery problem, I believe.
no i dont think i did a nandroid backup. but what is the best modern rom to use for this kind of problem.
and exactly what do you mean recovery problem? does that mean the phone might just be broke?
You are in a fastboot loop, this is a recovery problem when booting a rom, not a rom problem.
I don't work with recoveries, and you are asking for help on a retired rom, for a problem not rom related.
As for modern rom, try Harmonia or IHO. most other roms are no longer supported.
You shouldn't be trying to mix kernels and roms or even play around at all when you haven't even made a Nandroid backup. Get your phone out of fastboot and make a nandroid backup before you completely brick your phone. You have been playing with fire and you have no protection.
yeah but how do i get it out of fastboot and make a nandroid backup? none of the buttons on the phone are doing anything. if i can get my phone working again i am NEVER messing with this kind of stuff again. this isnt worth it lol
Do a search, a few people have had this issue, or post a new thread, hopefully one of the people with more experience with this can help you. Posting a dead rom thread won't garner much attention.
r3dpuk3
