Landshark
- Jan 11, 2011
- 4,434
- 1,382
- 113
Thanks Landshark I really appreciate that info, makes perfect sense to me and I couldn't agree more! I just got done flashing the non-voodoo ComaVolt kernel it flashed fine as far as I know. But afterwards I wondered to myself if I should of cleared the battery stats in cwm or wiped cache etc... All I did was go straight into cwm and flash the kernel without thinking to do anything else, was that alright? And as for telling if it is flashed you just have to pretty much know since it said installation complete, because the kernel number in the phone info remains the same correct? I'm definitely liking SC 2.9.2 with the black alien 2.1 theme, just hoping this comavolt kernel enhances battery life a bit, tho I can't say the battery life is that much worse than when I was completely stock!
On a side note I have another question.. When I'm in contacts and try to use the back button it does not exit contacts, I have to hit the home button. Is there a way to fix that? So far that's the only real issue I've encountered.
You should always wipe battery stats to reset calibration every time you flash a new kernel, whether it be a kernel by itself or a ROM that includes a kernel. Just make sure you follow the method in gunnermike53's battery thread HERE
Just make sure you add in a step 4b of after wiping batt stats, run the battery down to about 5% with normal usage, then charge uninterrupted back to 100%. You won't see full results for probably at least 3 days until everything settles in and the ROM, kernel, radio, and battery have a chance to work together for a while.
And you know the flash of the kernel worked if during the flash you had a bunch of blue lettering flash crazily all over the screen.
As far as the contacts issue, I'm assuming you are running Launcher Pro since that is the only launcher where this seems to be an issue. Easy fix. Long press the contacts icon, choose change shortcut, choose applications, choose phone, open phone, hit back button, long press same phone icon, change shortcut, make it contacts again, open contacts, try back button. If it didn't work, simply reboot and it should work now.
