[Retired][ROM]Superclean 2.9.2 EA15/EB01/EB16/EC10 Based
Ok, so I flashed CWM all. I want to put the old music player, the clock package and the TW Launcher. Since I have flashed CWM, could I download those three files from Adrynalyne's thread right from my phone. Press the power button until it gives me the different options, and press recovery from there?
I believe that is how some people have done it. Download to the sd card, boot to recovery, flash.
so it should recognize the three files and when I'm done, should I press the power button down again? or what should I do?
You are doing the same thing you would do if you downloaded these files to your computer then flashed them. You are just downloading the files straight to your phone instead of through the computer. Boot to recovery, flash the files through cwm, then reboot. If you don't know how to use cwm, click the link in my signature for DroidXcon's guide to cwm with screenshot visual aids.
Reactions: marteagajr75
I downloaded the files, and went step by step as in the pictures but it didn't have the files I downloaded so I went back all the way to the main menu where it says to reboot system. I didn't reboot system since I didn't apply anything, instead I hit the search key to go back and it left me with a blank screen and the four icons at the bottom lit up. How do I get out of this? or this I screw my phone up?
Can I flash 2.9.2 over full stock eb01 Rom without any issues?
Sent from my SCH-I500 using Tapatalk
If you are just flashing the ROM in CWM, then yes, you can flash directly over full stock EB01. You can even use DroidXcon's 2.9.2 package since you are already on an EB01 build.
I've tried searching this forum for the answer but I couldn't find it. Is there a way to change which toggles are in the status bar drop down on this rom? I apologize if its there and I couldn't find it. Thanks!
As far as I know, there isn't a way.
I'm not sure that is possible with any ROM
Nope you cant change them in this framework. Why would you want to change them out of curiosity?
Well, the reason I wanted to change them is I wanted different toggles up there. I don't know who really uses the auto rotate toggle very often so it would be nice to use it as a silent/vibrate toggle. And yes, sky raider for the dinc has it. It's what I have on my dinc and I wanted to see if its possible to do on my girlfriends fascinate. Sounds like its not possible though. Oh well. Thanks all for the help :)
Sent from my Droid Incredible
I used the auto rotate toggle all the time actually, I usually have it off actually.
What does the DRM package patch do? I already put back the clock, music player and launcher back on. Just wondering what that patch is, thank you
I did a google search on DRM and it seems it stands for Digital Rights Management which apparently may be a way Samsung controls what digital content you can view on your phone. I remember seeing Adrynalyne post that he removed DRM content, so I would guess the patch puts the DRM content back for anyone who wants it.
EDIT - further research revealed there is some DRM protected material, and if you want to access that, it would seem you need to install the patch.
Cool, Thanks LandShark. So basically we can do without, I have a similar question to the one posted earlier. I don't want to change the toggles but is there a way for them to look as they did before prior to flashing SC?
Only two ways that I know of: 1) Learn how to theme so you can change the images yourself; or 2) check all of the themes in JaeKar99's themes thread, click on the developer's name next to the theme name and look at the screenshots for the theme in the OP to see if any of the toggles in the quick panel look like what you want.
alrighty, themes roms etc etc EB01 EC01..i started off useing the rom which had EB16 and EC01 and those Rom's gave my fass the hicups. move the phone and walla everything went beserk. EB16 threw me in corner and just would not settle down,, so i went back from the ground up and stuck with the EB01 as close as possible. which has been a golden goodie.. mostly stable, DroidX said one night that Adryn.. stated the EB16 as unstable. my question is why do i see everyone scampering about and mostly EC01,
EB16, talked about in most threads.. Is the EB01 left in the dust ??
my ph reads as thus::
Firmware ver 2.2.1
Baseband S:I500.04 V.EB01
Kernal 2.6.32.9
Build # SCH-I500.EB01
with all the chatter about DL09, EB16, EC01 etc i wonder,did i miss something?
am i on the right track ?
thx in advance (i will tick the TY box, most dont,)
heritagevine16
