[Retired][ROM]Superclean 2.9.2 EA15/EB01/EB16/EC10 Based
I'm trying to flash this right now but everytime I hit usb debugging a pop up comes up and says accessibility services not available. I did a little searching and someone said it was completely cosmetic but when I plug my phone into my computer it says device not found. Anyone have a similar situation before or know a fix?
when you plug your phone into your computer, do you get a usb mount option in your notification bar?
I just tried with a different usb cord and now it's saying connecting packet service: restart phone :confused: Very strange.
Edit: and now it works....huh
Click "OK" on that pop up and you will be fine
I've had this same problem, finally figured it out. With the phone unplugged, go to USB settings and force the phone to "ask on connection". After selecting that, I haven't had any more problems with odd connection issues pertaining to USB mounting.
I have never flashed a rom through cwm, just through Odin. Is it going to wipe. Right now I am on 2.9.1 with ec10 voodoo and va green theme. Is all I have to do is flash 2.9.2 voodoo and reflash my theme, or will my theme even work with 2.9.2?
sent from my super clean 2.9.1 voodoo fascinate
Boot to cwm, wipe cache partition, wipe dalvik, flash 2.9.2 voodoo zip, reboot phone, boot to cwm, flash theme, reboot phone.
Reactions: stilltipin87
ok i know this has been asked and im missing it but its hard to find with 119 pages. Anyways i keep seeing about 3g mobil hotspot does it work for free (i know its use at your on risk) but im asking if the 3g mobil hotspot is what people are using or are they downloading a 3rd party app to teather?
Nope this includes the dummy tethering module so you shouldnt need a 3rd party app i believe
Note: it is in the changelog of the first post :-)
I'm successfully using Wireless Tether to do this and it is working correctly with the dummy kernel on 2.9.2. Used it to tether my nook color earlier today. The included 3g mobile hotspot app however does not work and just takes me to the verizon page where I can select a tethering data plan. Hope that helps.
So i need to download a 3rd party app to do this i was just asking so i dont do somthing and will f me when i get my bill. Thanks
Just took the plunge from DL30 to superclean 2.9.2. I really liked DL30, but I want to be like GunnerMike and see if I can mess up my phone by shoving worms in the phone. The first time I flashed it, I got stuck on the honeycomb screen for over 30 minutes so I cleared a few caches, reflashed and it worked fine. Now for some questions.
1. How do I get my apps in the list mode?
2. How do I delete the extra blank home screens?
3. Is this the latest version of Swype? When I try to load the latest version, I get a note saying that I do not have a license for this. I deleted the three files and tried reloading, but it gives me the same error
I knew how to do these things with my old rom.
Question about the lock screen. I was on sc2.6 using touch of blue theme and the rotary unlock (my favorite unlock) worked perfect. I am now on sc2.9.2 with no theme and the rotary unlock screen can be unlocked by pressing the menu key. If I add a theme will it correct that or is this in the ROM now? Would like the menu key to NOT unlock the screen. please let me know. Thanks.
1. thats a feature of the launcher. not launchers will do that.
2. see #1
3. if not just install the latest your self.
they were frogs smarty pants.
it did it in 2.6 as well. look on the themes and apps thread and look for the 6 lock screen...something. flash that. it doesnt have that "feature"
is it necessary to reboot after you flash the rom before flashing the theme? I did everything in order except reboot after flashing 2.9 ..before I rebooted, I went back to install from sd and flashed my new themes
2. see #1
So, Mr Smarty Pants who puts frogs in his phone because someone said they would make it jump farther and faster, :p I have 4 "home" screens. Two are blank and I don't want them. Does that mean that I cannot delete them? I don't want them, I don't want them, I don't want them :'(
Reactions: iLogikk
yes. you want to flash rom, REBOOT, then flash theme after the rom boots up the first time. if you dont your phone may not boot at all.
lol. so do you want them?
what launcher?
bradfromthevalley
