[Retired][ROM]Superclean 2.9.2 EA15/EB01/EB16/EC10 Based
I assume the GPS fix that was in 2.9.1 patch is included in 2.9.2. My GPS has never worked so poorly as when I had 2.9.1 installed. I will give it a shot and report back.
App auto-install (through the market i assume) is gone in this rev? I kinda liked that, but i guess for some its a pain.
FIXED IT. Going EB01 Debloated fixed the issue.
Knowing that 3G was always on, I knew that something else has to be the issue.
QCP messages from my wife's feature phone were coming to me as a jpg slide show. Reflashing with eb01 modem and samsung mms, clearing cache and dalvik, seemed to do nothing, as did scrubbing the phone per DroidX's instructions.
Used Odin to flash EB01 debloated fixed the issue without a hitch. Wife resent the same video, this time it worked. Previous pics and mms from her would not come to me, but now they are.
Adrynalyne, that said, if you happen to want those files sent to you from her phone, pm me your mobile and I'll have her send them to show you what happened. If it works for you, then I'm stumpped and will stay on EB01 debloated until 2.2 is officially released and the devs release some new stable custom cores.
SuD
ok i have a question related to 3g enabled or not enabled on my fascinate..
i enabled it yesterday and it stated that I had to use a file from verizon..
i enabled it anyway just to see what would happen.. of couirse enabled with nothing to test left me in the dark..
I dont want to get hooked by verizon, so if i enable it ,, does verizon have anyway of knowing i have it enabled it.???????????
Just initiated dl on my home pc via Pocket Cloud on my FASN8. Should be done by the time I get home.
Cuz I can, that's why. :)
Swyped by my FASN8.EC10_superFRANKENclean2.9.1 voodoo via Tapatalk
Question: I am running 2.9.1 with the ec10 kernel, will I gain anything by flashing 2.9.2 other than a possible headache? I finally have this thing tricked out and running smooth.
I flashed this and it went through great! Now when I tried to flash a theme back on its taking forever to reboot... Tried putting NitroDark. Its stuck on the bootanimation. Any ideas?
SHOWOFF :cool:. I left my usb cable at home today. Good thing I had a micro sd adapter and my work computer has an sd card slot. Now just waiting to get my battery to an acceptable level before flashing.
Reactions: papa54
Just flashed 2.9.2 voodoo about 1 1/2 hours ago can confirm that swype does work, GPS locks on in 10 seconds outside 25 seconds inside. Battery seems to be hanging in there. Will report back later about more and battery life.
Thanks again Adyrnalyne!
Also- Just found out that you only need to push the search soft button once now to bring up google where as before is was 2 pushes.
Anyone know what file the call log is in?
Lost call log and would like to backup from previous nandroid.
Anyone else lose their call log after flashing this?
Used 2.9.2 as an excuse to do a fresh wipe AND move to voodoo..
Which brings me to my question After a wipe/clean flash I end up with two apps for movie playback Movies and Video Player.. Curious if one is better than other and why a choice wasn't made for one over the other in the ROM.
Thanks Adyrnalyne! for all your efforts..
you know , that memo kinda gave me a snicker.. no puns intended as i have no idea of what i am doing,, i just do it and if i dont like i , i use CWM to recover an earlier backed up version,,
no way do i mean anyting stated as something detrimental...
what would be to my advantage to switch from non-voodoo to ---Voodoo
Prince08900
