ghostrider5666
- Sep 18, 2010
- 120
- 3
- 0
I need help I factory reset my phone and now it wont go past the samsung screen.
What do you mean by factory reset your phone? How did you do it? What build were you on before? ROM? kernel? etc.
I did it with clockworkmod and I was on 2.9.2 kernel EC10. My phone would not go past the samsung logo. Should I odin back to stock?
So you did wipe data/factory reset? Did you also wipe cache and dalvik cache? What did you flash after doing that? Were you on voodoo or non voodoo?
Yes and I did nothing after that on non voodoo.
Hey there nghthawk. Haven't seen you around in a while. Have you seen this thread about the "sleep of death" problem? http://forum.androidcentral.com/ver...-trouble-sleep-death-eb01-superclean-2-x.html
It's a bit of a drawn out process, but people are reporting success with it getting rid of SOD.
As far as the email sync, many of us have found that to be a problem with the stock email program not the ROM. A lot of people, myself included, have switched to K-9 mail and I have had no problems since. Polls and syncs email much more regularly.
Haven't seen the problem you are describing. Sounds like something related to the instant function where Google starts searching for results as you are typing. Just below the search window, turn off instant if it is on and see if that is what is happening. Other than that I will play around with it a bit to see what you are describing. Is this with the stock browser or another browser like Dolphin or Firefox?
For battery life have you tried one of the new EC10 based kernels that have been released in the past two weeks? They are great on battery life because they are undervolted. You can find them in post # 4 of Jaekar99's thread HERE
I am in the market for a tablet, and although the Samsung looks tempting, I absolutely will not give Samsung any more money until they get with the program. I can only be thankful that I got my Fascinate on a free promotion, so the only pain I endured was $38 in tax......
We wait with baited breath, sir!!
Sent from my Froyo Fascinate using Tapatalk.
Is there a way to add backup assistant back onto a rom? I really don't prefer to use google to backup my contacts and I like that I can easily recover contacts both on this phone and any other vzw phone with it.
I dont see that option in account and sync under settings but I see that BackupAssistant.apk file is already in the package have you tried running the setup wizard to initiate it?
I go to setup - it says click start to begin backup assistant - i click start and it just immediately goes to the setting up a google account step.
Strange. Same thing happen to you?
hmmm weird when i clicked on start it takes me directly to the page for entering my pin for backup assistant. Did you just flash this ROM as of now? If so go through the google account setup first then try the backup assistant through setup wizard again.
No I've had the rom for a while. When i go to add a google account is says this account is already on the phone. and then nothing about backup assistant shows.
I see, well do you have root explorer or any any file explorer with root access? Try pushing the APK to system/app and make sure to disable read only. Other than that I you can try reflashing 2.9.2 again to see if it shows up?
