[Retired][ROM]Superclean 2.9.2 EA15/EB01/EB16/EC10 Based
So I just flashed to SC 2.9.2, but then did a factory reset...when it prompts me to add my Google account credentials, it just says "Sorry...Your username and password do not match. Please try again." Is there a secret to get my account back on there?
Never mind...I forgot about the 2-factor authentication and that I'd need to regenerate an application-specific password for my phone.
I'm running SC 2.9.2 and using the clock weather app Beautiful Widgets. It seems like once or twice a day it loses its settings, and I have to go tell it to use geolocation again, and which clock skin. Is this just me with this bug?
EDIT: I deleted the BeautifulWidgets folder from the SDCard/data and reinstalled BW and "knock on wood" it seems to be working again.
I can't remember if anyone has reported that specific bug, but I do know a few people have reported bugs with BW. BW was also found to be the cause of some force close issues with superclean. I have had no problems with BW though, so I'm sorry I can't be of more assistance.
just flashed this using droidxcon's pack with odin.
i was trying to update to the latest swype and that requires me to uninstall current swype and swype installer. but i can't uninstall swype (settings->applications->manage applications); the "uninstall" button is not highlighted / cannot be selected.
anybody else have this issue?
edit: lol nvm. just uninstalled it using titanium backup.
You have to use a file manager like Root Explorer or Astro Manager, both available in the market. You use them to go into the system/app folder and delete the swype.apk
Reactions: vi3tboiii54
To add on to sharky's post you also need to delete libSwypeCore.so from system/lib and com.swype.android.inputmethod from data/data before pushing the latest swype to your phone.
Reactions: Landshark
Thanks Captain. I forgot about those steps. I think there's a third one that will block the install of the new beta. Let me find it.
Nope, I can't count. Those are the three:
system/app/swype.apk, /data/data/com.swype.android.inputmethod, and /system/lib/libswypecore.so
i recently switched back to superclean from MIUI. in the MIUI alpha ROM, there were issues with the Camera. when i switched back to superclean 2.9.2 the video camera was working again, but no audio is recorded. do i need to odin back to fix this issue? Or is there a camera APK out there I should use to replace the existing camera APK?
edit: resolved camera audio recording by odin back to djo5, all good. :)
If you wanted to go back to SC 2.9.2 you can fix the audio recording issue. I assume you used the voodoo kernel. Go into voodoo sound control -> recording preset -> and check original
voodoo sound for audio input is still broken as far as I'm aware
To quote Sam Elliott in Roadhouse - "I'll get all the sleep I need when I'm dead." :D:p
EDIT - Although I am dragging pretty hard today after only 3 and 1/2 hours of sleep last night.
I'm beginning to think you are nuclear powered....
Another Round Fired from Tapatalk
I was picturing sharky as "Jaws" unstoppable swimming through the forums at late hours looking not for the helpless to feed on but those in need of help or to make a quik joke...
DA DUM....DA DUM...DA DA DA DA
Bye the way I have all the jaws flix.!!
finally decided to install 2.9.2 and the first thing i noticed is that my battery life got better like twice better. upgraded to 2.9.2 on sunday 2am unplugged it after 100 percent and havent plugged it back again since tuesday 1am. did some facebooking, zynga poker, email and txt messaging, few calls and some missed calls lol. And no i did not clear the battery stats. maybe got lucky the first install, see how it goes on the first week. No bugs so far
Heh....give a few days and get back to us :)
2.9.2 is GREAT...BUT, i've noticed a marked degradation in battery live over the past month. Luckily I have the Seidio 3500 extended battery.
Support for /dev/tun?
First off, many thanks to you Adrynalyne for these ROMs. I flashed super_frankenclean 2.9.2 a few nights ago and have had no issues. Without the real contributers like yourself, the rest of us leechers would be left in the dark.
So now for the question...
I'm trying to get VPN to work, and don't see a /dev/tun or seem to be able to locate a tun module. Do you have a module for this or are you able to advise me on how to get working with the super_frankenclean rom?
In the meantime, I'll make some backups and mess around myself. If I stumble onto something, I'll share with all.
Thanks,
shonrs
jmyoung48
