Review Tudia case Slim-fit MERGE Dual Layer
Bruno Slivar
121
12
18
I just received case from Tudia
TUDIA Slim-Fit MERGE Dual Layer
Features: Dual layer design fuses a premium quality polycarbonate outer layer with an enhanced Thermoplastic Polyurethane (TPU) rubberized gel skin to offer slim, lightweight and form-fitted protection for the LG G5
Snap on design allows for easy installation and multiple colors are available to match your personal style.
Features raised edges to protect the display screen from scratches when the device is placed face down and a lip that allows compatibility with most screen protectors
Utilizing two layers, this cover incorporates the top safety advantages of both a hard and soft case. The soft inner TPU absorbs and disperses the shock of most drops encountered in daily use. On the exterior, the durable polycarbonate shield protects against scratches and still maintains the smooth and sleek feel of your device
Precision-Cut cutouts perfectly align with all buttons, controls, and ports. Allows easy access to the camera, speakers, microphone, and charging port without having to remove the case
Case look very nice. Not too much bulky. I have this grey colour and look perfect with my grey G5.
Case stay in hand very well.
Protection is on max. Front and back side. Tempered glass dont have problem with this case. This is my first tudia case and it dont be last one.
One of my favourite cases
TUDIA Products | Mobile Accesories
Crissy Doug
