Rezound Screenshots: Share them here!
Sent from my ADR6425LVW using Android Central Forums
Nothing too fancy -- ADW EX launcher but I'm liking some of the GO launcher screens I've been seeing... might have to mess around with that one.
According to Beautiful Weather Widget, tonight is a full Death Star - that's always a lot of fun o.O
Live Wallpaper = Blue Skies by KittehFace... love this LWG! looks great, runs great, doesn't do jack to my battery.
[YT]http://www.youtube.com/watch?v=o4__PBVc6Zg[/YT]
I've been a lurker here since my wife and I bought our Rezounds at the beginning of March, and for some reason I decided to make my first post a screenshot.
I'm running Go Launcher with Yankoa's MetroStation icon set, and Beautiful Weather.
So after about 2 months worth of fiddlin Ive settled on this.
-Clean ROM Developer Edition
-ADW EX Launcher
-Beautiful Widgets for the clock and weather
-Minimalistic Text for the Battery Percentage
Really liking Scope. Looks great and functions well. Still a few bugs but it's beta software.
Came across a very similar setup, decided to adopt & adapt...
Apex Launcher - (replaced system icons with MetroStation Icon pack)
Beautiful Widget - (weather information)
Minimalist Text - (time / date)
Tiwiz ICS Search Bar - (for the clear Google search bar)
Circle Battery Widget
Switched from Nils' Sense 3.6 Business ROM (best battery life, phone runs very cool but weak wifi on my end) to Viper (great rom but phone runs hot and battery life suffers greatly) to the NeoMAX rom (v1.4 atm) which is what you see below. It seems to strike the best balance between wifi/cell reception, smoothness and battery life tho it does have a few minor bugs here and there that mostly could be fixed by simply reinstalling an app or wiping its cache/data (think tonight's build should fix that out of the gate).
Home screen
Fancy Widgets Clock/Weather
Go Launcher EX using iOS theme
Droidicon for text icons
Tiny Flashlight + LED
Volume Control Widget
Juice Defender Pro
Battery Indicator (notification area)
Folder Organizer Pro
I used Picspeed Wallpapers for my background and used Picsay Pro to overlay my son's picture onto it.
These are the two screens to the left of my home screen.
Gentle Alarm widget
Period Tracker widget
Drippler widget (isn't loading at this moment for some reason)
Power Control widget
Business Calendar Agenda Widget
These are the two screens to the right of my home screen.
Google Play Widget
Folder Organizer Pro Widget
Slacker Widget
Verizon Widget
Catch Widget
Fancy Widgets Forcast
I also use Display Brightness widget. You can place it anywhere on the screen and easily have a slide control for brightness. It can be set to fade away after a few seconds. Also you can set it not to activate until you hold down for a second, in case you're always bumping by mistake. They also make a Volume Control widget with the same features.
Sent from my ADR6425LVW using Tapatalk 2
BekaH
