Ringing Noise
groberts0
Active member
Dec 10, 2012
44
Every minute or so a ringing noise goes off on my Nexus 7 - I presume it's a reminder on an app but cannot track it down + it is driving me mad!!! Any ideas how to locate the culprit please?
It could be a recent app you installed or possibly the NFC chip reacting to something like an electronic key card, student ID or really anything with an rfid chip
My nexus 7 does the NFC tone when it's near my college ID
If you mean the bar along the top, there is no notification. I've looked at the calendar, which had reminders and similar funtions but without result. It continues, occasionally, even when sleeping. Only turning it off stops the ringing.
Make sure NFC is turned off, as previously suggested. Do you have any timer apps installed. If so, check for alarm settings. Also, in settings check which apps are active to perhaps lead you in the right direction.
I turned off NFC + went through the calendar reminder again and it seems to have settled down, except, when I did download an App it rang. No problem as I was aware what the event was but whatever else had been setting it off was still unclear. Is there no way that if a reminder / alarm etc goes off attention is not drawn to the actual culprit? Otherwise you are just left to fish around to find the issue, or not.
liquidsnake757
