Robin's LG G Pad 8.3 Thread
cant play youtube videos when Bluetooth is on with wifi
It works with my note 4 phone but when i tried it on the gpad it said playback error.
Re: cant play youtube videos when Bluetooth is on with wifi
If you're using a 5GHz wifi connection on the GPad, Bluetooth could be interfering with it. (Some Bluetooth setups, in some devices, interfere with some 5GHz wifi in some devices. So your note 4 could be perking along just fine with 5GNz wifi and Bluetooth turned on, while the GPad won't work that way. Your router should be putting out a 2.4GHz signal also (on most of them you can turn the 5GHz radio on and off, or you can turn wifi on and off, but you can't have wifi on and 2.4GHz off), so connect the GPad (and the Note 4, if it's on at the same time) to the 2.4GHz connection and turn the 5GHz connection off. (You do that by connecting to the router with a web browser - see the router documentation or look for it online if you don't still have the book). There's no wifi device that I've ever heard of that can do 5GHz and can't do 2.4GHz, so it shouldn't cause any noticeable difference other than being able to use wifi and Bluetooth on the GPad at the same time.
re:
Do you mean in the App Drawer (the list of all apps that comes up when you tap the Apps button), or on the homescreen?
Wow thanks. I am glad there's an actual reason
Re: screen protectors?
Do you ever wipe your screen? Ever rub it up against something (a pocket, a tissue in your purse)? Then you need one. There are carbide particles floating in the air (they're so small that they're more subject to air movement than to gravity), that are a hardness of 9 on the Mohs scale (diamond is 10). Rub a screen with something not damp enough to float the particle off and a it will scratch the hardest tempered glass screen.
You don't need a $100 screen protector, though - the 3/$5 protectors will last about a year or two each, so for $5 you have about 6 years of protection. (Use transparent tape, sticky-side out, after you've completely cleaned the screen, to pick up any last microscopic dust particles - they're small, but the bubble one makes in the protector is about 1/8" in diameter and it's VERY annoying.) I'm still on my first protector after about 15 months. (If I hold it at just the right angle to the light, I can notice a few scratches, but they're not visible when I'm using the phone. And the pack of 3 cost me $5, cut to fit the phone. i-Blason at Amazon.)
re:
In the App Drawer view, tap the menu button (the 3 vertical button at the upper right)--are there options there for sorting?
Isn't the screen gorilla glass?
It's currently Gorilla Glass 3 (which is harder than Gorilla Glass or Gorilla Glass 2) - which has a hardness of 5-6. As opposed to the hardness of carbide at 9. Scratching Gorilla Glass 3 with carbide is about like scratching window glass with diamond. Your nails can't do anything to Gorilla Glass, neither can most metals. But a sub-micron size particle of carbide? It makes melting through butter with a white hot wire seem difficult. It's why people who wear glasses are told to NEVER wipe them dry - you wash the particles away with the spray, then wipe the grease off with the wet tissue. You can't spray a phone screen (if a drop of liquid gets inside the phone, it's going to slowly corrode and destroy the phone), but you can dampen a tissue with lens-cleaning solution and use that to remove fingerprints. Otherwise you're just smearing them all over the screen. (The part of the glass you look at the screen through isn't at the edges - even on an "edge-to-edge" display, there's a tiny strip of opaque glass, so you can wipe the entire surface of the glass you look through without a problem.) But it's the carbide particles that scratch even Gorilla Glass 3, and replacing the glass (which is cheap, but takes a LOT of experience to do without damaging the rest of the phone - which means you pay labor for someone who's spent a lot of time learning how to do it right - read: not cheap) is a lot more expensive than replacing a $1.67 piece of plastic protector. And if it takes you 2 whole packs before you get it right (and I don't think anyone is that clumsy), you wasted $8.33, not the $10 for the glass or the labor to remove the scratched glass (that's the difficult and expensive part).
You could use tempered glass, but that's not hard, it's tough. IOW, it will scratch, but it won't break on impact as easily as gorilla glass. Some day they'll come out with cheap tough diamond sheet (anything crystalline is the opposite of tough) and we'll worry about breaking the plastic case the phone is in before we worry about breaking the screen. But after many years of doing this, and replacing screens that were protected by various means, I've come to the conclusion that the second best way of protecting the screen is a cheap plastic protector. The best way is an Otterbox case with a tempered glass sheet over the outside of the screen cover (and that takes about $50 for the Otterbox, $10 for the glass and whatever you pay to get the glass cut to size. I haven't seen any tempered glass protectors for the outside of Otterboxes.) If you're not in the habit of dropping your phone, a plastic screen protector is fine. If you are, or you have kids who might, an Otterbox Defender is great protection. (And I'm retired, so I don't make a nickel out of any choice you make.)
I just ordered one from Amazon...got good ratings
power went off now its not working right
Our electricity was out for 3 minutes and I can use the gpad with the hotspot with my phone but if I use straight WiFi its very slow. I even reset the tablet...help
Re: power went off now its not working right
Did you try rebooting the router? Unplug its power for about 10 seconds, then plug it back in again, and wait a few seconds for the connections to reestablish. If that doesn't work, you might also consider power-cycling your cable or DSL modem (if that's how you get your internet service).
Yep but doing it again.
It might have more to do with your ISP. Have you contacted them to see if there's a problem in your area?
I got a replacement and so far so good. I think that one was defective.
caritas
