Rogers S6 still on 5.0.2
Anybody aware of any VoLTE enabled areas in BC, I'm assuming every LTE area works but VoLTE doesn't seem to be working for me on Fido. It might because I'm not on the new plans though.
Sent from my SM-G920W8 using Tapatalk
Should have nothing to do with plans, if your phone supports it you should be able to use it. Make sure the LTE area is strong strength, a solid dedicated signal for dedicated bandwidth is mandatory for initiating and using a Volte call. It should be avaliable in BC...I'll test today and let you know if its working in Toronto where I work. It may have been disabled temporarily on network side as mobilrsyrup is reporting a bug has halted software releases.
Update: I have tested near work in a well develop d strong signal LTE area and it dropped down to 4G for call so it looks to be halted in network config.
Here's another text from Fido that explains the problem:
Hi, it's Fido: You received a message from us yesterday to update your phone's software so that you could use VoLTE (Voice over LTE). Unfortunately the update didn't enable VoLTE. No worries though: whether you updated your phone or not, it will still be working as usual. We're working as quickly as possible with Samsung to send you a new software update that will enable you to use VoLTE. More info about VoLTE at fido.ca/VoLTEFAQ
janbibijan
