[ROM] [10.07.2011] NuDroid T1D-S [LG-P509] [Froyo 2.2.2]
arhtard - sad to hear that - again your ROM has been the best of the 3 that will work - solicit some donations - your followers will buy you another - don't give up - we need talent as yours !!!! - i'll donate 20 and i'm sure several others will ???
I second this. Could you let me know how I can chip in?
Hi. I am very happy with this ROM and I decided to unlock the phone and I was told that I could not apply the unlock code if the phone is rooted. So I unrooted it and now when I started the phone, I saw only the LG logo appear very shortly and then nothing happened.
Does it mean my phone is bricked?
Is there any way I can rescue it?
Thanks a lot.
Thanks a lot.
I downloaded the KDZ_FW_UPD.exe Updater with the stock firmware (V10L_00.kdz) and restored it. The only trick after that was that I needed to hard-reset; otherwise it just boots to the NuDroid logo and loops forever.
Anyway everything was back to the original firmware and I could unlock it fine. Will have to update to this ROM later.
Flashed this ROM weeks ago with no major issue yet. it is smooth and reliable. I do have one question, I would like to get the stock wallpaper for my A7 tablet and cannot seem to extract it. anyone know where or how I can get the image?
Thanks
Thanks
It's in framework-res.apk located in system/framework. Open the .apk with 7zip or winrar. The image will be located in res/drawable and is named default_wallpaper.jpg
Reactions: hairlipdogfish
This ROM looks great, but I wonder if CarrierIQ can be removed from it?
Otherwise I think I'm going to go with CM7.
Thanks for the hard work.
I'm not sure anyone is still watching this thread.
If you are, then I was able to download T1-S but was not able to download T1D-S.
Can someone post a link for T1D-S?
hey, I have a question, if I do this to my phone, what will it allow me to do?? I'm mainly just trying to make this phone useable with sprint. (I had it for T-mobile) thanks.
Sprint and T-mobile are different types of phones. T-Mobile is GSM and Sprint is CDMA. A T- Mobile phone will not work on Sprint and vice versa.
Sent from my LG-P509 using Tapatalk
when I flash this it is stuck at the splash screen, the rotating coin or whatever, and it just spins and spins, never boots up. what up with that
Re: [ROM] [10.02.2011] Boodoh V2D [LG-P509] [Froyo 2.2.2]
Can you make a video on how to do this? I want to update my OS. Thanks. The written DIRECTIONS are not very clear.
leehrenterprises
