[ROM][2.3.3][ZVJ] GingerRom v1.3 -4/14/12-
Re: [ROM][ZVJ] GingerRom v1.0 4/8/12
So let me get this straight, people on ZVH are flashing this?
Does this mean that ZVH roms will work with ZVJ radio?
And can anyone point me where I can see what the advantages of ZVJ over ZVH are for now?
I'm thinking about testing out ZVH roms on ZVJ radio if it's worth trying. Not sure if that's obviously a bad idea to anyone else, but I'm still new to android :/
after i flashed this it says im on zvj. i believe someone in the hydrorom thread said that it worked.
So... I'm gonna go try out one of the themes made for zvh on this rom. Wish me luck! :D
*prances off into recovery*
Reactions: rod_munch
OK so...it broke my status bar...LOL
Guess I will have to wait patiently for compatible themes :p
Everything else seems to be ok, but I kinda need my status bar, heh.
Yes, if your still on the ZVH baseband and flash this rom, it will state you have ZVJ, but that is just the build.prop telling your phone that. You still in fact have ZVH radio (baseband).
Yeah, lol I would have been amazed if they would have worked. Well thanks, that saves me the trouble of trying to bring the mods from hydro over the easy effortless way, lmao.
::Sigh:: It's gonna take more HOURS than you can imagine to port that stuff over. Honestly, I'm not sure I currently have the time to do it.
On that note, later tonight I plan on posting a community base for anyone to take and use as their own. It will have the basic necessities to build from. I'd like to see some creative work from you newcomers.
Oh it's fine, I just got bored and curious and figured why not be the guinea pig :D
Any chance of seeing you bring the black sms over? O:-)
Very nice rom i made one also but my dam computer got a blue screen as i was posting on here
Has anyone noticed any sort of double tapping on the stock kernel?
Yes, in one of the other threads people stated that they are experiencing some double-tapping with stock kernel. Gingerkernel fixes it.
after a reboot or two im having no touch issues at all. this rom is running great so far.
Great work. Was having slight double tapping but Gingerkernel cleared that up. Excellent work and speed at getting it out there. *High Five* :cool:
Reactions: jstntp
ryancode
