ARCHIVED: [ROM][4/05/12][4.0.3]MIUIv4 for OV! By Team A.P.P
Status
Not open for further replies.
Are you kidding, this place is worse than "Field of Dreams" If you post it, they will flash it.
Some of you are worse than crack heads!
Oh look, shiny!!!!!!!
Very true. I've flashed every single rom there was for the ov and some for the os :p
Sent from my VM670 using Tapatalk 2 Beta-4
If I flash an os rom will it harm the ov? Because one of the only things I see different is jus home and menu button switched
It could now because of the radio update, I don't recommend doing it most of them didn't even boot. I did it before spring did the zvh radio update
Radio updates always seem to ruin something XD
Re: [ROM][BETA][4.0.3]MIUIv4 for OV! By Team A.P.P
Sorry guys, but for the rest of the night I'm going to be ripping out my eyeballs. UNC just lost.. :/
More than likely it will be safe... Probably.
It may allow some newer roms, but disable older ones.
Keep in mind that on almost every OS rom, 3g will be disabled and you will need Harmonia 1 to reactivate it.
Prl's are safe to change. At worse, you will get bad reception, in which case, try another.
Why does it keep saying I don't have root access ._.
EDIT: Can't reboot into recovery, no option to do so, and when I try to run su in Terminal, it gives me "/system/bin/sh: su: not found"
Looks like I lost root :X
Reactions: rukin5197
This from isn't rooted. Because you lose root in a from doesn't mean your permanently unrooted, I just made a mistake.
Sent from my Amazon Kindle Fire using Tapatalk
EDIT: Would rerooting it fix the problem or cause more problems?
Just flash a super user zip. Google it
Post didn't go through for some reason, my recovery isnt working either, that's the thing. I can't flash anything at the moment (unless I can do it through ADB?)
I tried installing clockwork mod and reboot into recovery that way btu it stated I needed root.
DON'T USE CLOCKWORKMOD!
Just boot into recovery manually.
Turn off phone and press (hold) home+volume down securely, and then hold down the power button.
Reactions: notrankin
Status
sikhanegi
