[ROM][5.07.2011][ED01]Community Rom V1.3
I can't get barnacle or wireless tether to work anymore. They both used to work fine for me, but now I get errors when I try to start to start either one. I've tried clearing the data, uninstalling and reinstalling, fixing permissions, and nothing has worked. It stinks because I now I actually need to use it and I can't.
Wireless tether is working fine for me... what exactly is going wrong? Did you check the log for errors?
Sent from my SCH-I500 using Tapatalk
Suddenly it is working. I swear I've been trying for like 2 weeks now. I can't remember what errors I was getting before, but now its working fine. Weird.
I went to try it so I could check the log and BAM! it was working. I tried everything I could think of. I even went back to the superclean rom that it last worked on, and still no go. This morning I did clear bstats, but wouldn't think that would make a difference. That's the only that is different that I can think of though. I'm just glad it's working again.:D
is there a way to make your own keyboard for this ROM? the tsm is a bit distracting. if its just a matter of making a jpg, maybe i can take a crack at making one where the logo looks a bit more stylish.
if not, are there themes where the TSM doesn't stick out so much or isn't there?
Reactions: flamingoezz
gunnermike has a thread where he will fashion a themed swype to your desire..just check the forum...
or click on LS link...he's nicer than me..
Loving KB1.3 so far. The only issue I have with it is the fact that lockscreens from apps no longer work properly (i.e. - PowerAMP lock screen can no longer directly unlock to the home page, I have to go through 2 lockscreens now.)
Kinda annoying, but everything else seems to be working great for me.
Anybody have a suggestion on a different kernel? I just seem to be having issues with every OTB kernel I have tried, even OTB 1.5. Even with everything uv at -25 I still have some issues with reboots, etc after a couple of days. I want to try something different to see if thats the problem.
I keep hearing good things about his one. I will give it a shot. Is the one from 4/11/11 the most recent?
Yes to my knowledge thats the most recent, and the one I have installed. It works wonders for me.. The other day I logged 15hrs since unplugged and almost two hours display time with 40% remaining. And it quelched some bug that was occuring with the proximity sensor on my phone (it would humm during a call if I had the phone in a certain position against my face)
since i'm running the Comm Rom 1.3, i can just flash the "EC10_ulv_voodoo.zip" voodoo comavolt kernal thru cwm and reboot and all will go well yes? do i need to clear cache's or anything before/after?
Never hurts to do a cache/dalvik wipe anyway, so I would recommend it.
Ayatokirizka
